Xperia Z 2. Screen damage
profile.country.IE.title
Grendow04
Member
Hello.
My Sony Xperia Z2 has sustained damage resulting in hairline cracks near the top of the screen. The touchscreen function is affected as a result. I can no longer scroll from the bottom upward to open the screen which is locked with a four digit pin. The device can still be switched on and off and charged as normal and the camera still works. The display seems normal as well, no pixels out. Is there anything I can do apart from having a replacement screen fitted?
Thank you.
1 REPLY 1
TheMaze
Hey @Grendow04
I believe that only a screen replacement should solve this issue
