- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi I knw that the wifi disconnects when u use the screen mirroring , but at the same time I also have a note 2 which has the tool called all sharecast but when I use that the wifi still works along with the screen mirroring any solution to make this work on our XZ? technically its not impossible but there should be a way around i would like to use my wifi during screen mirroring .. will this be addressed in the update ?
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
This has been investigated and unfortunately it will not be possible to support Screen Mirroring and WiFi connection at the same time in this Xperia Z.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi anyone knows an answer?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I can forward this as feedback but i don't know if it will be possible to use WiFi and screen mirroring at the same time.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
THanks Rickard , it should be possible as my samsung phones do it with all share cast , they are connected to wifi and also mirror at the same time..
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Rickard,
The one year old Samsung galaxy s3 is able to have both wifi and screen mirroring active at the same time, I'm sure Sony's new xperia z should be able to do it to.
Any update on this matter would be appreciated.
Thank you in advance!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I tested my brothers Xperia T with screen mirroring and his wifi connection did NOT get disconnected... If the Xperia T is able to have both WiFi and screen mirroring simultaneously then the Xperia Z should be able to, shouldn't it?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
totaly agree so hopefully it comes in the next update as a fix , coz I wanna stream videos using my wifi not my mobile data
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Rickard , any update on this if this will be achievable on the Z? , not wanting an ETA but just that want to know if it will be implemented.. if not can anyone suggest an alternate app which can achieve this ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Will this be added as a feature on any upcoming builds ? , as its really annoying to loose Wireless when on screen mirroring... SONY please add this feature to have both...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
