Accelerometer stops working
Mikvandorp
Visitor
The accelerometer of my x performance stops after some days so auto-rotate and other stuff does not work anymore until I reboot...
Tags (1)
410 REPLIES 410
GreenCopperz
Visitor
The work around are only temporary and don't even work a full day for me or many others. We are rightly agitated and are venting our frustrations.
Bashaps
Visitor
Same problem here i tried factory reset workt fine for aan hole week. After a week same problem auto rotate stops working after about one hour or so terrible Phone overall
Ericz
Visitor
Hi, just got my Xperia XP back from Xperia Support Thailand. Sony Thailand engineer confirm to me Accelerometer problem came from hardware issue not software!!! they change new M/B to me. Let's me test for 3-4 days will update problem solve or not.
*** Update ***
5 hours after Sony Xperia Support Center replace new main board to me, all the problem was occur again with new problem with proximity sensor not functional.
poor not professional with Sony engineer in Thailand.
tereniaFlo
Visitor
Hi Support,
I encountered a number of screen problems with my Xperia X Performance.
First of all, every time I talk on the phone and accidentally press my ear to the screen, the call drops. I believe it is because of a high sensitivity of the screen. BUT it seems like it is not possible to change the sensitivity settings in any other way than by writing code understood by the phone's system. Before putting a phone on the market, you should remember that not every user is a developer and not all of us want to look like wide-arms bodybuilders answering the phone in this weird angle:wierd angle phone-answering
Second of all, I have been resetting the display and camera hundreds of times to fix the problem with the photos being rotated by 90 degrees while stored. This makes swiping saved photos uncomfortable and posting then on social media a nightmare because they have to be rotated in an editor EVERY TIME!
Please, oh, please, can you fix these things???? I really liked the phone so far...
profile.country.PH.title
MarlonUk1
the problems you are experiencing is due to the problems discussed here: http://talk.sonymobile.com/t5/Xperia-X-Performance/Accelerometer-stops-working/td-p/1158490/jump-to/...
survivant
Visitor
The display rotation doesn't work. I have the option auto rotate activated.
When I reboot the phone, it works for few minutes, but after that it stop working.
Any one have the same problem?
DmitryDN
Visitor
Try remove Google app and disable location history (read the thread 1-2 page ago)
Bfonteyne
Visitor
after 10 days without restart i noticed now the problem is back.
It seems like every time i post here to indicate it looks like it is fine, it will come back Face_with_rolling_Eyes
1222354
Visitor
Same problem build 275 bought in Czech republic.
Bmikkelborg
Visitor
i have the same problem, started last week....
