Accelerometer stops working
Mikvandorp
Visitor
The accelerometer of my x performance stops after some days so auto-rotate and other stuff does not work anymore until I reboot...
Tags (1)
410 REPLIES 410
Bfonteyne
Visitor
I'm also having the same issue.
Mostly I notice it when taking a photo, the rotation is incorrect.
Before it happened like once in a while but now it seems like a daily issue.
Very annoying since my photos are in a wrong position and by the time the phone is restarted, the photo moment is gone
My build: 35.0.A.1.275
Rb87
Visitor
Yeah, both me and my partner have the same issue with our X Performances too
HikaruKaze
Visitor
I have the same problem with the newer build... (282)
Never had any problem before. The gyroscope working properly but the accelerometer stops working..
After restarting it's all normal again.
I'm not installing any new apps...
xluigi
Visitor
Hi guys,
My Xperia X Performance (bought in Hong Kong) suffers continuous failure of both gyroscope and accelerometer function.
I notice it when trying to use the camera, then I perform a test confirming both accelerometer and gyroscope are not working.
After reboot is fine, but it is quite annoying doing so.
It is the F8132, Android 6.0.1, Build: 35.0.A.1.282...
I am trying by progressively uninstalling apps ...but I have seen at least one guy here who has similar problem (gyroscope only) without having installed new apps.
So, any suggestion?
Thanks
Regards
Uliwooly
Test your phone in >>> safe mode for few hours, see if you experience the same issue, if you don't then it's a third party app causing this.
Pentium
Visitor
Accelerometer stops working X performance  build .282
HrEnx
Visitor
Got same problem with my X Performance bought in Estonia
KMH1
Visitor
I have the same problem whit my X performance i got yesterday.
webwude
Member
I had it once. Fortunately since then no more issues so far.
Vikont
Visitor
Build: 35.0.A.1.275
F8132
Got it Sony Store.
Why is the phone that Sony called "flagman" have such issue long time?
Amazing
