Battery Backup Issue Xperia E4g
kailas
Visitor
HI,
Sometimes my xperia E4g battery drains from 14% to directly 1% in just few 10 to 15 minutes,
And sometimes runs properly
My Imei
Dont know whats the problem with battery.
Sometimes when i switch off my phone it also does not get start for atleast 5 to 10 minutes.
Is there any problem with chipset or charging/backup chipset.
Regards,
Kailas
17 REPLIES 17
syd21
Visitor
My phone drop from 60% to 1 and switch off immediately.
When is 100 it drops with 4hrs when I use WhatsApp.
Pls it irritating since from the day I bought
sa24
Visitor
hi. i had the same problem in past one week. what we do now. if you know abut this plz let me know
light2
Visitor
Im having a battery problem i use the phone connected to the charger if not it shurt down when i turn it on. It shows battery empty and off again where can I get a new battery
Niranj
Visitor
Yes, The problem does exists after trying the steps mentioned in the given link. Is there any solution for this problem?
fiveonetwo
Visitor
I had the same issue on my e4. Idk whether the software or the battery caused the problem. The battery status was good but i wasnt sure it was gucci. Then I flashed and rooted my phone, none of them worked, but strangely the battery replacement worked. I even replaced it myself to make it cheaper, lol.
felisko
Visitor
Good day everyone!
Please I want to know what causes my SONY XPERIA E4g Dual. Battery goes off even at 91 percent
Max40
Visitor
It is a little late answer for you but I just wanna share what I fond on internet. Look how this guy fix problem with battery in this link Sony xperia E4g battery problem
Maybe this will help to other ppl with this problem.
Tofeski
Visitor
Where is the link?
