Можно ли поменять местами кнопки назад и обзор? Сони Иксперия Е 5.
Can I swap back and review? Sony Eksperia E 5.
GT
Solved! Go to Solution.
Hi @krupnik,
This is an international community and I have translated your previous post to English using Google Translate. Please keep all future posts in English so that other users may more easily understand you.
If you are referring to the navigation buttons on the bottom of your screen, there is no way to change the layout of these.
Let me know if this answers your question or if I misunderstood you.
Hi @krupnik,
Понятно. Спасибо.
Clear. Thank you.
GT
Anytime! :smileysmileythumbsup: Let me know if there is anything else you are wondering about!
