Remote Start Suddenly Not Working (Again)
EuanCh
Anyone else having this problem. After months of constant problems with remote start (either from Google Cast in Netflix, iPlayer etc or with Sideview) it seemed to be working well and reliably. In the past few days it's completely fallen apart again. Is this just me or is anyone else experiencing the same?
2 REPLIES 2
Anonymous
Not applicable
Hi there
I can only suggest a power reboot at this stage - Press and hold the power button on the remote control for 6 seconds or so and the TV will reboot itself.
Cheers
Budhi108
Member
I had same problem. But, change batteries and now is ok. Is it possible that new Sony batteries full drain in one mounth? If disable bluetooth help long life batteries?
