bravia netflix has started to audio descriptions for blind
sparky8787
I have a KD-55S8505C and all of sudden the audio descripitions have started in netflix. It's so annoying how do I turn it off. It's only doing it in netflix though.
Software version 5.1.1
Please help before I go mad.
Thanks.
1 ACCEPTED SOLUTION
Anonymous
Not applicable
Hi there
Seems like you have changed the Audio settings in Netflix.
Before playing the Movie/Show, choose "Audio and Subtitles".  Then another menu will appear.  Ensure either "English" or "English 5.1" is selected and not "English - Audio Description".  See example screenshots.
Cheers
2 REPLIES 2
Anonymous
Not applicable
Hi there
Cheers
sparky8787
Thanks that's fixed it. It was in a slightly different place.
Doh! the kids turned it on. I reset the tv and it was still there.
Thanks very much.
