SONY NEX-7 External Mic Noise
tarchuiko
Hello
I'm having a trouble with my external mic. It works well with other devices. But I hear noise in the videos recorded with my camera.
Here is a video example: https://youtu.be/zs2yKlxbkJA
Thank you for any suggestions about this issue.
Uploaded by Тарас Чуйко on 2021-05-23.
7 REPLIES 7
Joe_Dohn
Specialist
Does this happen on the latest software version for you?
tarchuiko
Yes, I have 1.03. Is this the latest version?
Joe_Dohn
Specialist
According to the support page, it is the latest, yes.
Have you tried resetting the camera or using a different external microphone?
- JD
tarchuiko
Resetting didn't help. I've tried a mic from my headphones. It works better. It's strange because the camera mic works fine on PC. I think the problem is with audio levels, I can't find any settings about this.
HannahEd01
Hey tarchuiko , which mic are you using?
tarchuiko
@HannahEd01 I'm using Boya BY MM-1
Bat_Rick
Hi Tarchuiko,
I would recommend getting one of the fully compatible microphones using this link.
