Loose lens
roknigh78
Loose lens
im having trubble with my lens's they are loose can i fix it and what would it be
4 REPLIES 4
Anonymous
Not applicable
Hi there,
Which camera are you using?
Best wishes,
M
roknigh78
It is a sony a65
Sent from my Samsung device
EdwinaU
Moderator
Hi Roknigh,
Thanks for getting back to us. If you are having trouble with your camera lens you can get some advice from a repair centre here.
Best wishes,
Ed
roknigh78
And how much will this cost me and I did say could I fix it myself
