- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hello,
I bought the Sony Experia Z on Friday 22, 2013. Yesterday evening I changed the picture of my lockscreen. After I've changed the picture my icon for the quick start function of the camera is gone and I can't get it back. Could someone tell me the way to re-install the icon (and functionality)?
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
if you have a pin/password lock the quick launch will be gone
if you don't have any of the above then
camera > settings > quick launch
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
check from camera setting if quick lunch function is turned on or not , also try to change the background again and see what will happned otherwise factory defualt is the solution
you may use PC software to backup all your data safly
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It works. Thanks a lot for the quick help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
anytime
