Search for contacts takes several minutes
gilpl
Visitor
When searching for contact it takes several minutes have approximatly 5000 contacts any ideas how to reslove it? the same apply from time to time when using the SMS?
Thanks,
gil
1 ACCEPTED SOLUTION
Uliwooly
you probably have way too many sms/mms and/or call logs, that do slow down your phone and/or phonebook/phone app.
5 REPLIES 5
Uliwooly
well you just point out the reason why it takes so long to show your contacts or search for a contact.
try this
delete all your call logs, sms and mms, if you want to back them up, do so, either use the backup & restore or use
sms backup+ or another sms/call logs apps
if that doesn't work use another phonebook app.
Don't forget to mark the Correct Answers & Helpful Answers
gilpl
Visitor
Thanks for your advise but at the begining (a week ago) had the same number of contacts and it all was smooth? suddenly the all use of the devise seems to take ages...any advise?
Thanks much,
Gil
Uliwooly
gilpl
Visitor
Thank you, worked out well!
Have a great day!
Gil
Uliwooly
anytime
