- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
HELP! My screen is dim and I cannot brighten it. What's wrong?
I have had my z3 for a couple months now. Yesterday the screen dimmed down significantly and will not brighten back up no matter what I do. I have turned of "Auto Adjust" and all that. I have manually increased the screen brightness to maximum and it does not thing. The current brightness is good enough for indoor use in a area with not much light, but in a bright room or outside I can barely tell what is on the screen. I have powered the phone off and restarted it several times. It's like it is stuck in some kind of battery saving mode that it won't come out of. I made sure that all battery saving modes are turned off. Nothing effects the screen brightness no matter what I do. Please help!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have a similar issue but I can't see my screen unless I hold a flashlight to it even on maximum brightness. Any suggestions? Everything is off and brightness is maximum and can't see the screen without a flashlight.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I tried what you explain I had off adaptive brightness and it works thank you sooo much
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Translation via Google Translate:
Hi, I'm just asking why I'm just wondering why my brightness screen is dark how do I do it for you back then. Thanks
Hi,aqu po c karen rosales itatanong ko lang sana kung bakit po madilim ang brightness screen ko po paano ba gagawin ko po para po bumalik sa dati.salamat po
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I change my damage Sony xperia L1 screen after my screen can not light but I can't see any thing unless with torchlight or flashlight. Is the problem my phone or the screen problem please help me
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
My new Sony Xperia phone screen's light is dim, how do i fix it?
- « Previous
- 1
- 2
- Next »
