XA drain during GPS navigation
ng71
Visitor
Hello.
I have the XA since end of January. From the beginning I have the problem, as during navigation if the screen is ON (as usually), the battery is draining also if it is plugged to the charger. My old phone Z3C working well from the same charger, same apps. I did a factory reset, tried different charger. If the screen is OFF, the battery is going up very slowly. I took it to the local Sony service, they changed the battery, but still I have the same problem.
Does it need differenet charger, than Z3C???
Thanks.
Gábor
0 REPLIES 0
