Usb Otg problem
DhruvNimavat
Visitor
Usb Otg problem
Xperia xa dual f3116 updated to latest version.
One usb pendrive (hp) works fine with otg cable.
Other pendrive with same format (moserbaer) dont show up.
Other problem is when i connect my HP pendrive it shows in "es file explorer" but doesn't in storage.
There is only two internal and sd card. Then where is my pendrive?
Also reading data in that usb is fine but cant copy anydata from pendrive. It gives error for not permitted.
14 REPLIES 14
Pars987
Visitor
I didn't see this kind of your problem before , maybe factory reset or reinstalling firmware by Sony PC application may solve your problem and don't forget to backup your data before these 2 ways , also check OTG cable with other device and try some other flash drives
mahar
Visitor
Thanks for suggestion, after updating ES file Explorer now my mobile Explorering USB device via OTG cable. Thanks.
ashok135
Visitor
Does XA Ultra Dual support OTG
Jas_pal
Visitor
My xperia xa is not supporting USB OTG. What can I do.
Renji13
Visitor
having the same issues... has this been resolved?
