SD card error
Ryan26
Bezoeker
SD card error
Sometimes I turn my phone on and i cant access anything on my SD card, and other times i will get notifications saying 'SD card unexpectedly removed' and something along the lines of 'SD card not supported'. What should i do? Is it my SD card or my phone?
Thanks Slightly_smiling_Face
5 ANTWOORDEN 5
Jake-SonyXperia
Kampioen
Hi @Ryan26,
Welcome to the community,
Sorry to hear about this issue, let's see if we can help resolve it.
The first step I suggest would be backing up the SD card to a PC/mac computer and then formatting the SD card, in most cases the issues is related to bad data on the SD card simply removing it with a format generally resolves these types of issues.
Let me know how you get on.
Ryan26
Bezoeker
Ok, thank you! I'll give it a go Slightly_smiling_Face
Jake-SonyXperia
Kampioen
How did you get on with this method did you have any luck with it?
Please let me know.
Ryan26
Bezoeker
Hi, it worked fine for abit, but now my phone has started getting the same notifications again but when i tap the 'erase and format' button it just closes and says unable to format and my pc can no longer read my SD card. Do you think it's the card? Thanks Slightly_smiling_Face
Jake-SonyXperia
Kampioen
This sounds like the SD card is not functioning as it should, honestly, I would suggest replacing the SD card, I think this would be the best option in this case.
Sorry for the late reply.
