Lesegoth
Visitor
call blocking
How to block someone's call?
2 REPLIES 2
Uliwooly
@Lesegoth
If you want to send to voice mail an specific contact
open contacts > select the contact > edit > menu
if not, then you will need a third party app to filter/block calls.
Emil
Enthusiast
Hi @Lesegoth and welcome to the community.
As @uliwooly suggested you can forward all calls from a contact directly to your voice mail. To do so go to: Contacts > Contact don't want calls from > Tap the pen icon > Tap ... > Check the box for all calls to voice mail.
If you want to block a number from contacting you in any way you will need a third party app for that.
Let us know if there is anything else you are wondering about.
