There's something up with my background, here's a pictureThe size of the apps is smaller and it seems like there is a whole new row of space on the right
Solved! Go to Solution.
Hi @Raph653 and welcome to the community!
It looks like you have changed the display size to small. You can change it back if you go to: Settings > Accessibility > Display Size > Default.
Let me know if this answers your question.
Yes, that helped, thank you very much
What to do ?
Standard
That's great to hear! :smileysmileythumbsup:
Let me know if there is anything else you are wondering about.
There's also a new option included in latest version of Xperia Home launcher to change grid size and icons size as a result. You can find this option by long pressing on any empty space on your phone screen, then choose the "Grid" option. You'll find some different grid sizes to choose from (4x4 is the default).
