- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
January 2017
January 2017
Quick select icons after updating to Nougat
Hi
I recently updated my Xperia X from Marshmallow to Nougat, i observed that icons of quick select - those on the bottom at main screen (which doesnt move while moving screens - pages of desktop) aren't so spread than they used to be. I mean i had only 4 icons (which was similar to 4 columns of icons at main screens, and they were making straight columns of icons. Now quick select icons are tighter - close to each other, and look a little bit odd, i had to attach 5th icon in order to look pretty, but still... It was done for purpose or what?
6 REPLIES 6
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
January 2017
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
January 2017
January 2017
I can't but i solve the problem just a minute ago. After i updated to Nougat i suffers battery drain, i have the same problem like XZ, XP users (topics at forum) and i just read to clear cache of internal memory holding power off button and volume up for 3 seconds. I did it for the battery drain, but it solved problem with quick select icons now they are 4 in straight columns. I will see if it worked for the battery.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
January 2017
January 2017
keep in mind that since this is a major update, it will be wise to reinstall the update.
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
January 2017
January 2017
XZ XP Xc users did that (Xperia companion software fix) and it havent solved the battery drain problem. But still i will wait for Sony to solve it in software fix.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
January 2017
January 2017
yes, some of the users might report that software repair using Xperia Companion did not workout for them, but it might work for you though.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
January 2017
January 2017
Ok, today i recieved a software update, it took 30sec to install, now i think the battery drain stopped.
