Bose SoundSport Compability?
Mikael30
Visitor
Recently got a Xperia X Compact due to my old z3 Compact's speakers died. Issue is that my cabled Bose Soundsport is not recognized by the phone at all. They worked fine on z3, and perfectly fine in anything else. Still if I connect them in the Xperia X Compact, nothing, absolutely nothing happens.
Is this a common and known issue?
5 REPLIES 5
Uliwooly
@Mikael30
If your headphones work with other devices, and other headphones work with your Xperia X then there's nothing wrong here, just a compatibility issue. Contact Bose regarding this (compatibility info)
Mimismo
Visitor
I have a probem with my Xperia X and my BOSE QC20, when I connect the headset to the phone, sound/music star plaing into the headset but after a few seconds music stops and no more sound is output to the headsets, if I play again the audio is played into the phone speakers.
If I unplug and plug again, the audio starts and stops after a few seconds agin...
This only happen with my Xperia X, I have another Xperia Z2 and works perfect, same headset works with my Samsung Galaxy S6 and of course in the Iphone.
Is there a fix to this? I have the latest software for my Xperia X...
Uliwooly
@Mimismo
Contact Bose regarding compatibility devices and/or issues.
Mimismo
Visitor
Yes sure ... I am not going to trash a Bose device .. maybe I will trash this Xperia X that suppose to replace the Z line ... perhaps for a Samsung device again that by the way works great with my headsets
YouHaku
Visitor
I am considering to buy Bose earphones and when i tried, same symptoms happen. No i don't think i will buy until this is solved. So any solution?
