Accelerometer stops working
Mikvandorp
Visitor
The accelerometer of my x performance stops after some days so auto-rotate and other stuff does not work anymore until I reboot...
Tags (1)
410 REPLIES 410
GuilleXP
Visitor
Screenshot_20161111-105353.pngDownloading 90 mb update.
Bernphoto
Visitor
Is working?
GuilleXP
Visitor
Yes 2 hours and counting
Philip0
Visitor
Download last night, much better
+ Gyroscope works fine
+ No more touch screen problems
+ Much better battery life
+ 10 to customer service
Ericz
Visitor
1 day passed after update seems screen rotation problem was solved..
JohanKarlsson
Visitor
The problem still isn´t solved. Works for a couple of hours. It's ridiculous how long this have been going on. Regret buying this phone. Sony should be able to fix a problem like this way faster!
webwude
Member
Even with 297? You would be the first who still has this issue.
Daco
Visitor
I have 1 week with my Xperia x performance and the accelerometer is not working properly.
I have to restart the phone every moment.
Is the only way can work, but just few minutes..
I need help..
My software version is 35.0.A.1.282
webwude
Member
Please read *sigh*
Temporary fix: disable Google location history
Permanent (?) fix: wait for new firmware 297
Philip0
Visitor
For those who live in a restricted update country and still have this issue, disable google location history:
- The location history only records where you have been, as opposed to location services which is used by apps like Pokemon Go & Chrome & Maps to help you navigate places some more info can be found in an article by Alex Dobie at Android Central
This shouldnt be an issue if your Xperia build number is 297 check under:
Settings > About phone > Build number (last entry)
No issues for my phone for two days better battery life also.
