- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
September 2016
September 2016
The accelerometer of my x performance stops after some days so auto-rotate and other stuff does not work anymore until I reboot...
Solved! Go to Solution.
410 REPLIES 410
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
November 2016
November 2016
Thanks for the info.
I'm glad that the Nougat Update will fix it. For now I use the workaround with disabling Google location history.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
November 2016
November 2016
Webwude - We did read, some of us are still having problems like myself after having did the supposed fix. Chill...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
November 2016
November 2016
My Gyroscoop constantly stops working causing my screen to get stuck and not rotate. If I reset my phone it's over for a couple of minutes. Does anyone have an idea how to fix this problem. My phone is only one month old and I'm not very pleased with this! Thanks in advance!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
November 2016
November 2016
Same here. Too bad because I've always had Sony phones without problems. Now I have bought the most expensive one and it's very disappointing. Makes you not want to buy one again. How do I sign up for "NOUGAT" like NC_knet..?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
November 2016
November 2016
Disable Google location history.
Reboot.
Done.
Reboot.
Done.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
November 2016
November 2016
Webwude. Nope.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
November 2016
November 2016
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
November 2016
November 2016
@creepwood: it works definitely, tried it with four devices. Check again.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
November 2016
November 2016
Webwude. When you say it works, you really mean "it works for you". Doesn't work for me. And besides, stopping no one service to gain abother is still not working.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
November 2016
November 2016
@creepwood OK, it works for my device, a friend, a colleague and his wife. Support recommended it as well. If it does not work for you you might double-check or reset or whatever.
I didn't get your last sentence BTW.
