NW-ZX507
ProJules1
NW-ZX507
LDAC stuttering @ 960 Kbps
even at a short distance LDAC stutters.
I have tried developer mode
I need some tips.
I have a living room set up using an Ifi Zen Blue Bluetooth receiver.
I have set my 507 up to transmit LCAC at its best quality to the Ifi receiver but I am getting audio stuttering when just a few yards away.
So for now, I am using AptX-HD (which is stable). But I would rather use LDAC @ 990 Kbps.
For LDAC I tweaked the settings in developer mode to try to lock it on the 990 Kbps best quality. But I notice it always defaults back to “adaptive” mode. (It won’t stay locked on best quality mode).
But the audio stutters and is unusable. Does the 507 have a weak LDAC transmission at its highest bit rate?
anyone else struggling to keep their 507 locked on best LDAC quality?
Do I have to reboot to save developer mode settings?
Anyone else having 990 Kbps LDAC transmission issues?
Tags (3)
2 REPLIES 2
Hi ProJules1,
Probably the connection is not stable enough for quality mode or there's something interfering with your BT network. I would suggest to change to stable mode to avoid such drop-outs/stuttering.
Cheers
Peter
Win_88
Specialist
I agree with @Peter_S.
You can further test this by trying to use the same exact settings in other places (with less interference) if possible. But it makes sense because signal issues are more noticeable on higher bandwidth signals for obvious reasons.
Win_88
