annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Windows XP
CuteeJazz
Visiteur
Windows XP
Hi ! :cool:
Is it possible to have XP Home in CD Rom in order to have no problem with the upgrading
(SP1)
I recently upgrade my OS with SP1 and I have recently a lot of problems:
-My chipset sound doesn't work
-the short cuts of my keyboard doesn't works (I don't know how to make it right :cry:
-.... (too long) :laughing:
If you have an answer please tell me :smileyrolling_eyes:
6 RÉPONSES 6
profile.country.en_GB.title
kee-lo_
Membre
Hey Cutee Jazz
You can buy XP Home edition from most good stores, otherwise you'd have to make do with your recovery CDs.
As for your sound, well go to windows update, a driver should be there.
Make sure you get the shared libraries from vaio-link.
CuteeJazz
Visiteur
Thank you for your prompt reply. :cool:
As you know the OS of the Vaio in an OEM version. And the problem is if I replace the hard disk by a new one (blank) Will it works with the recovery CD.
For the problem with the chipset audio I found the solution in this following adress:
http://www.yamaha.co.jp/english/product/lsi/us/support/downloads.html
NB: As you told me I 've try to update the chipset audio unfortunately.That's why I find the option on the yamaha site.
Don't pay attention to mistakes :wink:
kee-lo_
Membre
Well, we had this discussion once, and many people said that it can be done, I personally think it can be done, but some people around here would say it can't - maybe they'd like to elaborate on this for you.
Thanks for the driver links, maybe they should be added to this "useful links database" Club VAIO are making.
PS: I take it you have heard of DJ Cutee B? (DJ for Alliance Ethnik?)
CuteeJazz
Visiteur
You are welcome :wink:
Yes with the song "Respect" :slight_smile:
kee-lo_
Membre
Yes, and Simple Et Funky.... :slight_smile:
They're one of my favourites :smileygrin:
CuteeJazz
Visiteur
I like this song to :smileygrin:
What kind of music do you listen ? :cool:
