- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
lost both mouse and keyboard is there a solution? help please
good morning all
yesterday after a restart, i could not use my mouse, i got into safe mode and thats when i found that i could not use the keyboard for the help search, i used the assist button in the did a check on the disk (the mouse worked in that mode) which was ok.
I left the computer running overnight because although there is no control i can hear as if it is trying to access the mouse (that sound when you unplug and replug the usb for the mouse) with no success, i find using the assist i can get the full menu for diagnostic and recovery, but obviously i cant use my mouse.
i have another hd with some (not up to date) using now, with caddy i can see the problem disk but cannot see in in windows explorer.
any ideas?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Sony vaio vpcee3z0e windows 7
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
sorry double post
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
this all kicked off from a Internet security software. on some rare cases if installation or removal hangs, can cause incomplete installation or removal, and it can cause the problem that i now have (i wont say which brand it is, i quite like the product and will continue to use them after hopefully this is resolved.
i thought i would check out other options.
right now i am in contact which them and they / we are trying to fix it albeit with a tool that i dont think is working all that good.
if that dont work out will return to this, would be interesting to know if the other guys problem had the same source.
i have already managed a system restore to earlier good date, on pre startup that dident do the trick.
will keep watching with interest.
regards
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have with the help of KIS support and recovery disk (after many boots) managed to recover the use of mouse and keyboard.
I can now see that I am dot due an easy ride.
The first alert I had in this new situation, on booting I got>
SMART hard disk error>please consider backup of the hard disk>press esc. (I pressed esc)
I noted which I haven’t seen before, two versions for selection -"windows7 home premium (recovered)" and "windows 7" (I selected the former).
Got in, all looked in order, mouse/kb working BUT due to what happened (long story) before, I have 2 installations of KIS, I have special removal tool for removing all in the meantime due to conflict?? I am not protected. One of the advices for removal is "system restore".
System restore has got a problem and when I try trough sys prop > sys protection> unexpected error on property page, the file name, dir name, or volume label sys is incorrect. 0x8007007B - close and try again.
I have also been using some of VAIO CARE, did a scan of disk indicated no problems.
There are some other parts of vaio care that I have nor used that require internet connection. I have un plugged my internet cable because since KIS conflict whatever protection is nonexistent, I don’t want to get infected by rooming trojans seeking vulnerable connections.
I kept getting messages of imminent disk failure and possible even when disk check in vaio care was running.
I suspect I am rambling on too much but right now I haven’t a clue of the best way forward, is the disk really about to fail, loosing all that work, and system restore, one of the options I used when booting up (pre keybd/mouse) was to select restore to earlier date, it did not resolve the problem and not even sure it went back or failed.
