Unplayable mp4 DLNA streaming on 40EX653 TV.
tiptonian
I have recently added a Buffalo Linkstation NAS to my network. Includes DLNA streaming but more limited than I expected and there is no transcoding support, so I can no longer stream .mkv files like I could when I was using Universal Media Server on my PC.
Most of my files are .mkv, so obvious alternative supported natively by my 40EX653 TV is .mp4 as in theory you can just copy the video and audio streams across to the .mp4 container without transcoding. However I'm having problems with these .mp4's playing. For example I have an mp4 file that Mediainfo says contains:
Format                                   : MPEG-4
Format profile                           : Base Media
Codec ID                                 : isom (isom/iso2/mp41)
File size                                : 1.36 GiB
Duration                                 : 1 h 39 min
Overall bit rate mode                    : Variable
Overall bit rate                         : 1 964 kb/s
Writing application                      : Lavf56.36.100
----Video----
Format                                   : MPEG-4 Visual
Format profile                           : Advanced Simple@L5
Format settings                          : BVOP
Format settings, BVOP                    : Yes
Format settings, QPel                    : No
Format settings, GMC                     : No warppoints
Format settings, Matrix                  : Default (H.263)
Codec ID                                 : mp4v-20
Bit rate mode                            : Variable
Bit rate                                 : 1 513 kb/s
Maximum bit rate                         : 9 500 kb/s
Width                                    : 720 pixels
Height                                   : 304 pixels
Display aspect ratio                     : 2.35:1
Frame rate mode                          : Constant
Frame rate                               : 23.976 (24000/1001) FPS
Original frame rate                      : 23.976 (23976/1000) FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Compression mode                         : Lossy
Bits/(Pixel*Frame)                       : 0.288
Stream size                              : 1.05 GiB (77%)
Writing library                          : XviD 73
---Audio----
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Codec ID                                 : ac-3
Bit rate mode                            : Constant
Bit rate                                 : 448 kb/s
Channel(s)                               : 6 channels
Channel positions                        : Front: L C R, Side: L R, LFE
Sampling rate                            : 48.0 kHz
Frame rate                               : 31.250 FPS (1536 SPF)
Bit depth                                : 16 bits
Stream size                              : 318 MiB (23%)
Service kind                             : Complete Main
Default                                  : Yes
Alternate group                          : 1
The TV i-manual says that it can play MPEG4 video with AC3 audio so is it possible to say what it is about my file that prevents it from being played?
Looks like I may have to transcode some, maybe all of my files after all. Any suggestions on what to do or avoid to get playable files (using Handbrake) please?
1 REPLY 1
Pascale_F
Moderator
Hi tiptonian,
Welcome to the community.
It's worth contacting support about this here.
Thanks,
Pascale_F
