RM-ED053 Remote Control ?
NikolasP
Hello ,
anybody knows the code of this remote RM-ED053.....?for Sony Bravia KDL-32W651A
Thanks.
3 REPLIES 3
Anonymous
Not applicable
Ive had a dig around and cant seem to find the remote codes - but isnt it the connecting equipment that you input the remote codes for the TV's remote control?
NikolasP
Yes it is..but i would like to try a universal remote control the ''One For All Smart 7960'' , i have some codes by the manual and they do operate the sony remote control but not completely....but anyway i can also teach the remote control with the macro commands.....
Thanks for the help.. :slight_smile:
Anonymous
Not applicable
Gotcha.  I was just a bit confused thats all.  :slight_smile:
Thought that this might also be related to your sync issue anyhow.
