KDL-EX320 - Codec support
profile.country.en_GB.title
rmiller1976
Visitor
Are you removing the ability of this TV to play certain codecs and if so why are you reoving this functionality?
Thanks
1 ACCEPTED SOLUTION
Catmambo
Contributor
No, not as far as I'm aware. Where did you read this?
2 REPLIES 2
Catmambo
Contributor
rmiller1976
Visitor
It's not something i've read, it's plating fewer codecs. Got into the habit of converting files to mp4 because i knew it would play them - then after an update it would play mp4 video but not the sound.
