Can anyone tell me if I can run my iTunes through a Sony Bravia internet TV? If so could you explain in simple terms how it can be done? I'm not too good with technology.
Many Thanks.
How do I play iTunes videos through my Sony Bravia TV
I too bought TVmobili. It seems to work ok.
Hi, I know there is a new technology introduced by TunesKit. Their products can make the iTunes movies drm free and stream to Sony TV directly. http://www.tuneskit.com/drm-m4v-to-devices/stream-itunes-movies-to-sony-bravia-tv.html
For the iTunes Movies, iTunes contents are all protected by DRM so it is no way to play iTunes media to Sony TV directly. You can use TuneFab M4V Converter to play your iTunes videos on Sony TV.
At the beginning, I thingk it is difficult to do that, but it isn't. I am so happy that I found that easiest way to play iTunes movies on sony TV, basically you just need to do several clicks to strip the DRM protection. Compared to other tools, it doesn't have any rings or bells that affect you to use the software smoothly. Check it out. Honestly I was so surprisingly when I found it.
