Hi Keyman_1388,
In order to receive software updates, make sure the Automatic software download setting from your TV is turned ON. This way, as soon as an update is available for your device, it will start downloading automatically. If you turned this setting OFF, you will have to manually check if updates are available for your TV.
I will also pass your feedback to the team.
Best wishes,
Sean Mc
Thanks a lot buddy, your help is appreciated. Anyhow it was set to the on position before.
