Internet TV BBC Iplayer
profile.country.en_GB.title
Sony-Tony
Visitor
HI
Last night I attempted to watch Merlin on the BBC IPlayer through my KDL40ex713
First I used the high quality mode this took an age to load eventually I had a picture but it kept pausing to load more so I stopped the feed and restarted using the low Quality option
Same issue making the show un-watchable
Turned on the Blue-ray player BD-PS 370 loaded Merlin high quality mode no problem with the playback
Any suggestions why this should be?
I should point out I have a fast Internet connection & both the TV and blue-ray are connected to the Router via Ethernet cables also both firmwars are up to date
1 ACCEPTED SOLUTION
Catmambo
Contributor
They are delivered using two different mechanisms due to the differing architectures of the devices. Blu-ray is my preference as its basically iPlayer Big Screen same as PS3 but with the addition of HD content..
Thanks
1 REPLY 1
Catmambo
Contributor
Thanks
