Can I display PC content on my Bravia wirelessly ?
profile.country.en_GB.title
CAAUTO
Visitor
greetings to all
Just bought a KDL 40EX403 and am realy happy with it.
I am guessing it must be possible to watch my laptop content ( including live internet) through the TV using the wireless LAN set up, but I cant seem to find a way, please could someone help ?
Many thanks in advance
roy
1 ACCEPTED SOLUTION
Catmambo
Contributor
Why would you want a USB to Ethernet adapter? It already has a Ethernet socket.
11 REPLIES 11
Catmambo
Contributor
To browse the web you would need to use something like this -http://www.q-waves.com/qw/default.asp?title=Quicklink-TV&contentID=17
Thanks
snow6oy
Visitor
I'd like to connect a KDL-32EX403 to a home network using ethernet cable.
Other forum posters have mentioned a USB dongle. I can only find a wireless adapter (uwa-br100) in the Sony Catalogue. Does anyone know if any USB to Ethernet adapter, like this Belkin will work?
http://www.belkin.com/IWCatProductPage.process?Product_Id=104991
thanks,
snow6oy
Catmambo
Contributor
gofrost
Member
yes providing you install dlna server on your pc windows media player pre installed  on pc if running windows this is quite limited though there are others like mezzmo wild media server and twonky media i have used ethernet cable to connect my 503 tv and blu ray player to my home hub setting up is easy just use on board tv menu's my pc is wirelessly connect to hub using external adaptor and mezzmo connects to either with out any fuss auto converting files to play on either device my tv only has 1 usb port so if that's used you have to keep unplugging to use flash memory just use standard cat 5 cable to connect ethernet tv does'nt have drivers that is why sony dongle has to be used for wireless
Message was edited by: gofrost
CAAUTO
Visitor
Thank you all very much for your help.
So...would it mmake life easier all round if I did a cable connection between PC and TV ? Would I still require special software ?
Please advise what cable if so ?
thanks again to all
Roy
Catmambo
Contributor
Hi roy
  • If you want the built in video services, you need to run Ethenet cable or use the Sony Dongle.
  • If you want the built in video services + open internet then you'd need the product I first linked to.
Thanks
snow6oy
Visitor
Oh right. Um to explain my apparently idiotic question I was researching a xmas present for my Dad. He lives in another house so I haven't actually seen the TV, just downloaded the manual. blah, blah. well thanks very much. leaves stage left whistling tunelessly ...
knoxjohngraham35
Re: Can I display PC content on my Bravia wirelessly ?
Anonymous
Not applicable
If you have a newish TV that supports Miracast and Windows 8,1 - Yes you can:
https://www.youtube.com/watch?v=tzwqdKhkkMM
Extra für Günter Born ;-) Zum Beitrag: http://www.borncity.com/blog/2013/10/30/miracast-bei-windows-8-1teil-2/
