hi
my experia can browsing everything with smoothly via wifi,,but why can not i download something from android market?
everytime i try to download,there is seem to become download,,but that is not.
thanks a lot.
Solved! Go to Solution.
Given what you have tried up to this point, it may be worth running the update service to try an resolve this:
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
What are your thoughts about this forum? Let us know by doing this short survey.
hi
i try to install update even if i see from PC companion,my phone is up to date.
my battery is full,,and my internet connection is fine,,but the download can not run.
my USB is fine too because that is write on that i must release the back key and also can confirm i want to download or not,,but everytime at download page,,the download can not begin.
i hope you can tell me,what must i do about it.
thanks
Did you successfully repair phone software? If not, follow Sam's advice, use Update Service for software repair. It will prompt you that your phone is up to date, just proceed to repair it. Just be aware that this will erase phone data completed, backup if necessary.
If you have not done anything yet, try the following first .... Settings>Applications>Manage applications>MENU (left hard button)>Filter>All>Market>Clear data, then try downloading again.
hi
thanks a lot for Sam and Gwhispererz,,i reinstall my software and it works :smileyhappy::smileyhappy:.
i really happy about this
thanks for your attention.
i looove this forum.
best regards
Glad that your problem is resolved.
