Just bought a new Spiro phone.
I have inserted a memory card and was able to attach it to my PC via USB and copy files to the memory card. When I detach the USB cable (safely remove!), the memory card content is not visible. No mp3 files are detected and using the File Manager, I can see no files on the memory card and the status shows 0 Kbytes. I am not able to create new folders on the memory card either. Get strange error message about illegal character in file name - will be removed, but nothing happens. I have tried to insert the memory card in another phone (not Spiro) and it works. I have tried to use another working memory card in the Spiro, but get exactly the same sympthoms.
I have also tried to switch of the phone and connect to the PC, then turn it on and safely remove, but not change.
Any good ideas ?.
/Martin
Solved! Go to Solution.
When checking the memory card, it showed out to be Class 4. I got confused by the mistake made by the vendor by specifying it to be Class 2. Further more, I thought that since the memory card was accessible from the PC, the phone was able to access and it was therefore correct. From this I guess that the phone exports the memory card USB interface directly to the PC and the PC gets direct control.
Well, all I need to do now, is to buy a new Class 2 card, I hope!.
Thanks a lot for the your help.
BG Martin
Yes, it seems your phone was acting as a USB card reader when connected to the PC.Glad you got to the root of the problem and hopefully a class 2 card should work.
