Problems with syncing calendar
GELÖST
Nicht anwendbar
I just got my Arc S and I seem to be having problems with synchronizing my google calendar in gmail with the standard calendar app on my arc s. I tried altering the agenda that is viewed in the app, but it only gives the option to view the phone's agenda. Can someone help me with this problem?
1 AKZEPTIERTE LÖSUNG
Akzeptierte Lösungen
uliwooly-wooly
Legende
remove your google account and then re-add it see if that helps
Don't forget to mark the Correct Answers & Helpful Answers
11 ANTWORTEN 11
uliwooly-wooly
Legende
are you trying to modify events that were posted by someone else (facebook)? or events that you created?
Nicht anwendbar
I was hoping that events added by me in my gmail account would appear in the app on my phone. Preferably synchronized almost instantly
uliwooly-wooly
Legende
they should
go to settings -> accounts & sync -> make sure both are selected
background data traffic and activate auto-sync, as well as having a data plan.
also tap on google -> make sure calendar it's selected
Nicht anwendbar
I just did it. However, I can't see the option calendar when I tap on google in this list. Have you got any idea how  this is possible?
uliwooly-wooly
Legende
when you go to settings -> accounts & sync -> google
you should be able to see
Sync Docs
Sync Picasa Web Albums
Sync Contacts
Sync Gmail
Sync Calendar
Can you take a screenshot (just black out your email address)
Nicht anwendbar
I'm there, but I only see Picasa Web albums, Contacts and Gmail. No docs or calendar
uliwooly-wooly
Legende
go to your Calendar app -> press MENU -> my calendars and make sure its visible
Nicht anwendbar
I see two phone calendars there and made them both visible. I still can't see the calendar option under accounts & sync though
uliwooly-wooly
Legende
