as the title implies my xperia go wont start. i have charged it for 2 days straight , and when i hold the power on button nothing happens , it just flashes at the bottom of the screen. help would really really be appreciated
Sorry Ullman4444, all I mean is once the vibrations have stopped, have you simply tried pressing the Power button on the side of the phone to see if it boots.
Hi ullman4444,
Welcome to the community,
Try the following first and let me know what happens.
Press and Hold together: Power Button + Volume Up Button for 10 seconds.
hi. my phone vibrated some but no other results.
After the vibrations, have you tried powering on the handset?
sorry but how do i do that ?
yes i have but nothing happens. also i accidentaly marked your answer as the solution. is there anything else left to try ?
Ok, you could attempt a software repair on the device with PC Companion.
