Hello guys, please help if you have an Idea. So I just got this new X8 and my friends who have it said that I should just update it and it will automatically add Arabic and Hebrew. I even saw it on their phones. But I updated mine THREE times and there is no Arabic at all. Why and what should I do?? Cheeers.
Solved! Go to Solution.
did you checked the link above? you can debrand using that link and get arabaic
go to settings -> Language & Keyboard -> Select Language scroll to the bottom, is it there?
if you have
android 2.1
build number
it will have arabic language, you can do it through here
http://www.wotanserver.com/en/sony-ericsson/se/xperia-x8-e15/unlock-tool/debranding-flash
I'll add a thread here later on
Don't forget to mark the Correct & Helpful Answers
No its not in the settings. Its build number is 2.0.1.A.0.47 .. Is arabic available for this or have to rely on the apps? =/
What is the problem, you don't have an arabic menu or arabic keyboard.
and did you try to use the custom ROMs in the xda, because i used them and they are good for arabic.
LAST QUESTION...would that kill my warranty?? I just got it, Not so keen to remove warranty
Thankx alot. Cheeers
it "could" void your warranty, but you can always re-flash/install the original firmware that came with the phone
