keyboard layout
RESUELTAS
No aplicable
keyboard layout
anyone can teach me how to change back to a standard keyboard layout. i've been using my xperia play for over 2 mos. now then today suddenly the keyboard layout changed to Chinese and I cant change it because there is no option to change it.
please need help it so irritating because the layout has been changed and the space bar becomes smaller.
thanks
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
Uliwooly
its simple, open your messaging app -> go to any conversation -> tap on the white rectangle -> long press the white rectangle -> tap on input method and choose the default keyboard
4 RESPUESTAS 4
Uliwooly
No aplicable
it worked thanks. . .
Uliwooly
anytime don't forget to backup everything on your phone just in case
Install backup & Restore app (works with arc, play, neo)?
http://www.megaupload.com/?d=I5CJUPJV
just to play it safe sync your contacts w/ google if you haven't already
open your phonebook
press MENU button -> tap on Send Contacts -> select all -> send it to your email
on your computer
-> download the file -> go to your gmail -> click on contacts -> click on more actions -> on the drop down menu click on "import" -> choose the file -> and click import
Uliwooly
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
one last thing
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
