install apps on external storage
RESUELTAS
No aplicable
hi, i have a lot of friends who are using xperia phones. we were wondering if it is possible to have the downloaded apps installed on the sd card instead of the internal phone memory?
and what is the latest android version for xperia x10 mini pro and xperia x8...
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
slimshaddy
Héroe
it is saying that because ur region doesnt have the update yetNeutral_Face
se launches its update in some countries then in others..
m sry but u have to wait..
9 RESPUESTAS 9
slimshaddy
Héroe
whats ur current android version ??
go to settings > about phone..
and tell..
also
if u have android 2.1 u cant transfer them to sd card
but if u have android version 2.2 and above u can transfer applications to ur sd card Slightly_smiling_Face
u may try this
go to settings > appplications > on sd card
the items ticked will be on the sd card..
and the items unticked will be on phone memory..
tap on any item and tap on move to sd card..
u can also try this app
https://market.android.com/details?id=com.a0soft.gphone.app2sd&feature=search_result
it'll help u to do the above thing in an easier way Winking_Face
slimshaddy
Héroe
u can transfer to ur xperia mini pro since it has gingerbread 2.3
but u canot do this with x8 cz it has 2.1..
and x8 wont have any update after this..i think..
No aplicable
well it says its up to date. i have the current 2.1 version. is there any chance this could be updated to 2.2?
thank you so much for the reply
No aplicable
i have the x10 min pro. it has the lates update of 2.1. not gingerbread..... i try to check for updates but it sas im with the latest version already
slimshaddy
Héroe
slimshaddy
Héroe
u have the x10 mini pro ??
m sry i tho u have a xperia mini pro..
m sry but this phone also is upgradable to just 2.1 and not above...
No aplicable
thank you so much for your replies. i do hope there will be an update.....
No aplicable
thank you for your reply...... that's the prob with se.... how come they limit the os version to just that....
slimshaddy
Héroe
i know it makes u angry but i dont know whats in their mind..cant tellNeutral_Face
i thot that 2.2 and 2.3 are expensive i mean to take the rights and all..
i dont know how that stuff works but this i do know..
that companies like micromax and many more are giving 2.2 above..
and their cost unbelievable..so low..
i know that their hardware, user interface is not at all gud
but they are managing to bring out phones with 2.2
then i dont understand why SE does not roll out..
