ELM media player troubles. Help? plezzzzz
Not applicable
since today, it seems my media player is not working. its opening, i can see which all media are there, but the songs are not playing, the videos are too, like stuck.
i switched off, removed battery n put it back, no change.
i did master reset, no change still.
the problem disappears when a call comes(or missd call), it rings. then immediately if i try, media works. once i exit, and retry, its stuck again.
same when i change ringtone volume. after i play ringtone, music works, after exit, problem persists.
any help? tell me why this is so?
i am really sad. Slightly_frowning_Face
1 ACCEPTED SOLUTION
gwhispererz
Champion
Hi, suggest software repair phone using PC Companion or SE Update Service. Here's the download link for both, http://www.sonyericsson.com/cws/support/mobilephones/downloads/elm?cc=gb&lc=en.
Be aware that this process will erase phone data completely (SD Card not affected), remember to back up.
Keep us updated and Merry Christmas ....:smileyhappy:
3 REPLIES 3
gwhispererz
Champion
Not applicable
thank u very much .... it is now woking
i did the update service
i re-install the software
once again thank u
gwhispererz
Champion
No problem.
Continue to enjoy your phone! Slightly_smiling_Face
