annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
charging problem :(
RÉSOLU
dimitrissd
Visiteur
charging problem :(
hello to everyone...!
my arc s is not charging when is  turned off
i turn off the device,and when i plug it in the charger,it shows me sony logo, -same time blue led- and then nothing.
i dont see the thunder any more as i supposed to ... 😕
could you please help me.? sorry for my bad english Slightly_smiling_Face
32 RÉPONSES 32
SaMo_HoSSaM
Visiteur
Done
show charging icon on battery but no change in battery level
Nabeel
Master
Was the problem there after you repaired your software ? ( before rooting )
i mean i told you to reinstall the software and then root. So did you check if your mobile was charging after repairing it ?
SaMo_HoSSaM
Visiteur
the main problem was after downgrade software by my friend i don't know what he did
i try many things about it and it never charge
yes i try after reinstall and no charge
root then follow you no charge too
i charge my phone on desktop charger 3 weeks ago
i want help to do it
the charger connector on the ohone is ok as it can do software
Nabeel
Master
Are you able to charge through wall socket ?
SaMo_HoSSaM
Visiteur
no i can't charge my phone any way
and if i connect the phone to wall charger if the batttery full it drain to 0 and phone shutdown
Nabeel
Master
Ooops, then you need to get it checked at service center. it seems to be a hardware default
placebo1
Visiteur
Hi, I had the same problem yesterday, and chargemon fixed it, but today I've tried to just disable USB debugging and it worked. No need to replace chargemon. Since you have to enable USB debugging to root your device that may have been left enabled and caused the problem. Hope this helps
oluwawapelumi_y
Visiteur
Hi Nabeel,
I have a major problem with charging too. I've downloaded chargemon but can't get it to open.
Nabeel
Master
Is your phone rooted and you're not able to charge post rooting ?
oluwawapelumi_y
Visiteur
Yes, it's rooted but I did that some months ago. However, I noticed it has become more difficult to charge since then - need to hold or arrange the phone and cable a certain way to ensure charging. Now, not even that works anymore.
