Xperia M2 blocked to an unknown network
treebush23
Visitor
Hi
I recently bought a second hand sony xperia M5 but it seems to be network blocked. Is there any way i can find out which network it is blocked to?
1 REPLY 1
Uliwooly
@treebush23
You should contact the seller as you will need to get the code from the network
