switched off problem
SOLUCIONADO
m2dual
Visitante
I face this weird problem every morning. Every morning when someone tries to call me they get a message that the phone is switched off, where as I can see there is a very strong network with full signal strength.
The problem goes away when I make the first outgoing call from my phone. The outgoing call connects without any problem, and after that the incoming calls just come fine.
I do not have any network coverage issue.
Could this be caused by any app ?
Another problem is on backside, when flash is one some particles of light are seen on all the corners as if the body is open. Can thesr problems be resolved.
1 SOLUÇÃO ACEITE
Soluções aceites
profile.country.RO.title
_alexdon_
Is the phone connected to wall socket over night?
alexdon
Ver solução na publicação original
10 RESPOSTAS 10
Big-Ray000
Visitante
I'm fairly new to all this myself, how about booting into safe mode one evening, and see what happens the next morning, that may eliminate any downloaded apps.
Just a thought until an expert comes along. Slightly_smiling_Face
Ray
m2dual
Visitante
Waiting fr an xpert opinion... It happend again this morning. Its irritating when you see a text alert of missed calls just because your fone is so called switched off...
amanronil
Visitante
I am also facing this problem Slightly_frowning_Face
_alexdon_
alexdon
amanronil
Visitante
Nope
_alexdon_
Try settings-apps-all-smart connect,force stop and clear data.See if the same occurs.
alexdon
amanronil
Visitante
this method not working.
_alexdon_
Try a software repair with SUS:
http://www.sonymobile.com/gb/tools/update-service/
alexdon
m2dual
Visitante
Yes it was connected to the wall socket?????? how is it related????
