ReSet Weather Location
NorPlan
Visitor
Have only had the Xperia M4 for a Week now and would like to Change the location on the Weather App (AccuWeather.com).. Have tried following prompts to No Avail.. Help Appreciated, Cheers Thanks
1 ACCEPTED SOLUTION
profile.country.RO.title
_alexdon_
If you tap on the small gear, you should get 3 options there, location, temperature unit and real feel.
alexdon
5 REPLIES 5
_alexdon_
Are you talking about the widget? @NorPlan
alexdon
NorPlan
Visitor
If you call the AccuWeather Bar across the top of the Screen a Widget Yes.. Sorry I'm not Tech Savvy..lol... Followed prompts by clicking on the Gear then attempted to No Avail to change the location given .. I know on my iPad our location exists through AccuWeather..
_alexdon_
alexdon
NorPlan
Visitor
Thanks.. As one who suffers from the occasional Fat Finger Syndrome.. Guess I wasn't as forceful with my Tapping..lol.. All is Good , Cheers
Spoiler
_alexdon_
Haha, no problem. Enjoy the device.
alexdon
