Solved! Go to Solution.
That is unfortunate, this could be related to other apps, can you booth the device in to Safemode and advise if the same issue occurs?
Hi santhire,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines
This could be a dialer based issue, you could try clearing the data from the Dialler application.
Menu > settings > Apps > All > Phone > Clear Data.
If you wish to keep all call logs, then I suggest you back up before performing the task.
That's good to hear, glad you were able to resolve this issue
