Deel jouw ervaring!
Next update for xperia M, Sony mod X-reality or BE for xperia M, Please! thanks sony!
SONY WRITE: "Those amazing moments you’ve captured. Your favourite sitcoms. Or that music video you love watching again and again. This Bluetooth smartphone comes with a bright 4” high quality display that’s perfectly sized for immersive entertainment – all without being bulky."
BUT. XPERIA M SCREEN IS BAD!
Opgelost! Ga naar oplossing.
That's quite odd, most likely its a network coverage issue, check with wifi
The Xperia M is a low end phone, The Xperia Z has Bravia Engine 2 and it doesn't seem that it will get X-reality, just like the Xperia S has Bravia Engine 1 and hasn't received any new updates on that department, I don't think the Xperia M could handle the X-reality engine, also keep in mind that the Xperia M has WVGA screen 480 x 854, with that said, if this was my phone I would root it and sideload Bravia Engine or the BE2 but that's just me.
thanks uliwooly!
on Xda Xperia L, M mod X--reality (CWM!).http://forum.xda-developers.com/showthread.php?t=2418968
xperia U has WVGA 480 x 854, CPU xperia M than xperia U, But xperia M not BE1,...!
i see picture, zoom picture is noise, play video on youtube (HQ) is bad, Xperia U play video on youtube (not HQ) is good than xperia M!....
I stand corrected, the Xperia M its a mid low range phone not low end phone, with that said, I would really look into sideload one of those engines if I were you
You can contact Sony directly here
thanks! i think Forum help me....
Because. On xperia Miro before I use, I have been asked to install BE installed, but sony is answered Miro xperia low profile, to fulfill the user experience should not BE. I think this forum will help xperia M. Xperia M see youtube pretty bad compared to Xperia U, Miro, (see HQ that every noise, shock, while the Xperia U does not HQ look very good) xperia M, U play is one video!
Fast video download speed (HQ)., but very noisy as 360p, ... when I compare with xperia U, then vieo lot sharper. xperia M play not HQ and watch the video without pretty bad, does not look well.
sorry for my english too bad.makes it difficult to understand.
both videos are at the same quality (360p)?
NO. larger is full HD (play on my laptop), But play on xperia M is HQ, Xperia U not HQ, but Xperia U is beautiful, xperia M is bad. xperia U 3.5'' (BE) sharp than xperia M 4'' or....
