How can I turn off this
РЕШЕНО
DeceiveR
Посетитель
Hi.
I have a problem with aplication.
I don't know How can I turn off this.
Look at the picture.
http://i.imgur.com/647ddUh.png
I think than it is "Mywallet" but I'm not sure.
Please, help me and write how can I turn off this.
1 УТВЕРЖДЕННОЕ РЕШЕНИЕ
Утвержденные решения
Thommo
That is the NFC icon which means your NFC is switched on - If you have a tools widget then open it and you will see that icon highlighted, Simply touch it to turn it off however if you don't have a tools widget then go to Settings and underneath Data usage or Bluetooth you will see More... open this and untick NFC
2 ОТВЕТ 2
Thommo
DeceiveR
Посетитель
Thank you very much! Slightly_smiling_Face
