Google Map mic issue
10121
Visitor
I look for help
I can't activate the microphone to search for an address on my google map.
I do not understand what happens. I used the three years that I have this Xperia m5 phone.
I've activated it on other occasions and now I can't find it
busco ayuda
No puedo activar el micrófono para buscar una dirección en mi google map.
No entiendo que pasa.lo usé los tres años que tengo este teléfono de Xperia m5.
Lo he activado en otras oportunidades y ahora no lo encuentro
1 REPLY 1
Uliwooly
@10121
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Could you try this
Settings > apps > Google maps > storage > clear app data > back > Permissions > Microphone > on
