Mic not working when on speakers or skype
Uli1970
Visitor
When i change to speaker mode during acall, my microphone is not working anymore.
Same when i use an app like skype, where the phone obviously also goes to speaker mode.
Any ideas whats going wrong?
I can record videos with sound.
Normal call everything is fine.
2 REPLIES 2
Igalgo
Visitor
Hi.
I have the same problem.
The microphone doesn't work when the speaker mode is on. That affects when I make videophonecalls or when I try to run the multimedia test for instance.
I could seem that has something to do with the noise suppression system, but it doesn't work either this is activated or not.
I you may have some solution, I will be thankful.
Uliwooly
@Uli1970  @Igalgo
Do you experience this issue only with Skype or other apps?
