Forgotten password
BoiWaddup
Посетитель
Forgotten password
Hello,
My brother trusted me his phone and asked me to reset it as he got a iPhone to replace it but he doesn't remember the password set on it. I've tried many different ways to get into boot menu etc but nothing has worked. Please if you have any advice whatsoever, help me out.
Thank you.
6 ОТВЕТ 6
Uliwooly
@BoiWaddup
simple, just ask him to unlock it for you, or ask him for the password or his Gmail
BoiWaddup
Посетитель
As said above the password has been forgotten and Google option doesn't work
@uliwooly
Uliwooly
BoiWaddup
Посетитель
I tried both options and none of which succeeded. My Xperia isn't activated and Google needs WiFi or Mobile Network to communicate with the phone, both are missing. But despite the failure thank you for your assistance.
Jonas
Мастер
Hi @BoiWaddup, welcome to our forum!
If neither of the options that @uliwooly recommended worked. You will have to perform a software repair using Xperia Companion.
Do note that this will delete all data stored on the internal storage of your phone and reinstall the latest available software.
I hope that helps! Slightly_smiling_Face
1231CHB
Посетитель
This method does not work anymore, I'm stuck here with a Sony Xperia M C1905 that does not have its password, it's a pin. I've forgotten it and cannot get back into it, despite how many softwares I try.
